Just added a back-up emergency cable to my Triumph, and the XJ6C may be next. Has anyone fabricated/installed any cables for their S1-3 XJ? Or is there a way to release the hood catches if a stock cable fails so that this exercise isn’t necessary?
Thanks, Brad
There are holes directly beneath the catches , covered by rubber blanking grommets and accessed from the inner wheelarch area… through which a screwdriver can be inserted to release the latch.
Obviously for use in case of (unlikely) cable failure.
Cheers, Mike
1973 S1 DDS
Great, thanks Mike - that’s what I wanted to hear. Maybe that is in my ROM, I hadn’t thought to look.
Brad
These work well. I had some difficulty setting the cables after restoring our car and had to use this method on a couple of occasions. Paul
