My '71 XJ just came out of the excellent frame shop. All is
well now with the hidden accident damage that the PO did not
declare. the doors all fit and the trunk lid. They now sound
like a bank vault and rest of the car body is 100%.
The rear tires have worn ‘‘funny’’ forever and all the other
IRS parts have been rebuilt by me in the near past. I
dropped it for new brakes, E brakes and rotors, calipers and
to change out the gears for a 2:88 LSD. All the rubber,
mounting pieces (4), shocks and springs are all new.
But, the rear end has a 1/4’’ toe out and I do not know how
to determine which side is ‘‘out’’ or it is a combination of
sides. Do not know for sure which side(s) were hit as it has
been improperly repaired previously, but suspect the drivers
side.
I can change the IRS parts out that are bent (probably a
swing arm(s) but would like to know which one(s). Then how
to determine if they are correctly pointing the rear tires
down the road?
Only know the front of the rear tires are 1/4’’ toe out from
the rear edge of the tire tread.–
'71 XJ6 383/200R, '72 XJ6 LT1/700R,'74 XJ6 383/700R
Glendora, CA, United States
