I have a 1987 XJ6 which I have owned for nearly ten years.
Begining about three months ago, I started to experience some
starting problems. The engine would crank over rapidly, but it
wouldn’t fire at all; sometimes, which I let the key return to
the ‘‘run’’ position, it would suddenly fire (sometimes not). In
examining the wiring diagram, I saw that 1980-on Jags had a hot
lead from the ignition to the coil, then on to the distributor.
The negative coil lead went to the distributor and to the ECU and
the tach. This basically reflects my wiring. However, my car has an
external ballast resistor with a connection to the coil and two
push connectors, one of which receives the white wire from the
ignition; the other connector is unused. I eventually discovered
that, when the car refused fire (sometimes it will start normally),
if I ran a jumper wire from the positive battery terminal to the
unused terminal on the ballast resistor, the car would fire. The
terminal on the starter relay that old diagrams show giving 12v to
the ballast when cranking is unused with no evidence of a wire ever
having been there…at any rate, it’s been that way for many years
without this problem.
So…questions: why do I have an external ballast resistor? Am I
supposed to have a coil with an internal resistor? What’s causing
this (the switch wire is always hot in run and cranking, HT lead to
coil is OK, connections tight, cap clean)? I thought of just
replacing the resistor, but I can find no listing (Moss, XK’s
Unlimited) for a ballast resistor for this year and model.
Any help would be much appreciated.
Bob–
robert manbeck
