Sorry for the lack of the correct part number
and description, however is there a source for
the nylon bushing on each injector whose
application appears to be to insulate(heat reduction?)
the injector from the head? If I remember correctly,
these currently may be non-obtainum. I have at
least one cracked.
TIA for any and all replies.
Rgds,
Kirk Yonker
1985 Jaguar XJ6 S3 Federal Spec
Seattle–
Wedgepig
In reply to a message from Wedgepig sent Fri 20 Jul 2007:
The F.I ‘‘seal kit’’ is NAPA part # 2-12083. It contains a large,
flat, thick, round seal and a similar shaped one that is much
smaller. (ones $.50 cent piece size + 1/4’’ thick and high the
other is slightly smaller then a dime) both in the box for about $6.–
Jim White, 87 XJ6 SIII, 79 Triumph Bonneville Special
Orange Park, FL, United States
[EAC 4403 - I literally looked all over the SE for them!]–
least one cracked.
In reply to a message from Trentbridge sent Sat 21 Jul 2007:
Thanks very much to everyone for the heads up
and supply advice. Ted is correct, I am looking
for EAC4403 Insulator Cone.
Ted mentioned that they became available again
about a year ago, and I just realized that I
haven’t paid much attention to list for the last
year or so. The car had been running fine only
until just the last few days. Yikes, I should pay
more attention to this list!!
Thanks once again for everyone’s support. I do
appreciate it!
Kirk!
Those are rubber rings to seal the injector from the intake
manifold vacuum leaks.
Available from any auto parts store like NAPA,Autozone etc.
Walter
78XJ6 ser.II--
