I thought I would post an update to this thread as my cat is
finally back to a pre-hesitation performance level. The original
post was:
''A couple of weeks ago I began to experience an intermittent
hesitation when I depressed the accelerator. It did not happen
every time nor with any pattern although it did get progressively
worse over the days. It was almost like someone cut off the fuel
until I let up on the accelerator and then it recovered. By the
time I put it in the garage, I had to occasionally feather the
accelerator to get up to highway speed. It really felt like a
clogged fuel filter but that was new and pressure is okay. Since I
needed a few things refreshed under the bonnet I did the following:
New air cleaner
New plugs,
New plug wires
New rotor
New cap
New coil
Removed and cleaned the breather screen’’
Okay, lots has happened since then including removing the AAV and
checking it out. I also found the hose from the manifold to the
back of the AAV was loose. I pulled the injectors and sent them
out for cleaning and all six came back with a good report. I had
the fuel rail modified to add a gauge and replaced the O2 sensor
which was completely plugged. I cleaned the over-run valve and
replaced the throttle body hoses. Cleaned the Mass Air sensor, all
of the electrical connections, replaced all of the fuel line hoses,
replaced the fuel pressure regulator and thermostat while I was at
it. After all of that the pressure on the rail was 28 pounds. So I
replaced both fuel filters, still 28 pounds. Swapped out the fuel
pump, still 28 pounds. Put the old regulator back on and it jumped
to 35 pounds where it remains. It now looks a bit better too.
http://www.jag-lovers.org/v.htm?1277376604
So now she is running pretty decent again but the engine temp now
ramps up to about 110C instead of the 90C it used to. The water
level is okay and the pump was replaced last month (when it was
staying at a solid 90C) so I took out the termostat and boiled it
on the stove, gradually raising the temperature. It began to open
at 85C and was fully open at 95C so no idea what’s going on there
except it is frigging hot outside. I guess I’ll wait till it gets
cooler and see if it goes back to normal.
Thanks all for your help in this.
Cheers.–
Scott - 1985 XJ6 SIII
Pennington NJ, United States
