Well the 1980 Buick Le Sabre fan clutch from NAPA does NOT work on my
engine…the hole is too small for the waterpump shaft to fit inside. It
was $52.00 with tax. I got a refund. (NAPA did have one that was spec’d for
the JAG but it was $190.00.)
Coventry West has one for about $90+. This makes twice now I wish I had just
gone to Greg’s: once for the heated O2 sensor (which I burned up and Advance
would not take back a second time - wrong part # - my bad) and now for the
fan clutch…Instead of being down for an hour I am now going to be out of
commission for several days as I now have other projects to attend
to…$#@%@^!!!
While at it, I checked the condition of the fan and it has a crack in four
places so my timing/luck is good. Only $350+ and she will be as good as new.
It has been awhile since I 've spent any real money on the Jag so I am due.
Glad I jumped on it before the really hot days got upon us. I have done all
this w/o taking the fan shroud off - what a friggin jigsaw puzzle getting the
clutch out first and then the fan! I confess to having loosend the air pump
though. And the P/S pump. Probably wind up having to take the whole radiator
assy out to get the works back in as my short term memory wont last even 1
day…
Ted Macklin
85 XJ6 SIII
135K miles===================================================
To remove yourself from this list, go to http://www.jag-lovers.org/cgi-bin/majordomo
to…$#@%@^!!!
day…
Ted et al,
I have heard about the Buick fan clutch swap but knew it may not be as easy
as it sounds. GM cars of that vintage used a variety of different engines
and, not surprisingly, different fan clutch configurations. For example, a
1980 Buick LeSabre could have the Buick design 350 V8 (Vin code X), Olds
type 350 ® or Olds 307 (Y), Pontiac 301 or 350 (Vin code ?) or perhaps
even the famous small block Chevy 350 (Vin code L). So, if you found a GM
“something or another” which works on our Jags, make sure to get the
specific engine info for future reference !
I don’t know, offhand, if it would fit on a Jag but one of the very best fan
clutches was the 78-79 Olds Diesel w/HD cooling option. About $170 (circa
1980 !!) but it really worked. Sounded like a cessa taking off with the prop
set at incorrect pitch ! Start your motor and the leaves blew for 20 feet
all around the car.
Doug Dwyer
Longview, Washington USA
snipped
for----- Original Message -----
