There are no fuses or relays for the wiper system in the console area of the
Series III car.
You should go again to the fuse, #6 driver’s side fuse box. REPLACE the fuse
- rather than inspect; make sure the cradle is tight and clean and check for
continuity.
There is a black load relay for the wipers on the fuse panel; the delay
relay is on the passenger side fuse panel just above the fuses.
Back to the fuse: I had an experience of no action from the wipers of one
Series III car. Everything was checked - I even replaced the fuse twice. I
looked at the motor connections, the switch itself, everything… What was
it? it was indeed in the fuse/cradle connection.
On these Jaguars the main components - in this case the wiper motor - almost
never go wrong. It is invariably the fuse, fuse connection or other
connections that are at fault. There can be exceptions, but that is what
they are: rare exceptions.
Gregory
Victoria, Canada-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org] On Behalf Of
W. Schuster
Sent: March-07-12 1:45 PM
To: xj@jag-lovers.org
Subject: Re: [xj] my series xj6 wiper has no power at fuse block #6
In reply to a message from kopperhead sent Wed 7 Mar 2012:
The delay unit relays might be behind the radio area.
There might be a fuse there.
What is the problem?
Walter
trying to trouble shoot windscreen wiper electrical .Does it start
at ign then go to fuse block,switch,motor ,is their a relay if so
where is its location?Any help would be appreciated.
Walter Schuster 78XJ6 FI Ser.II
Albuquerque/New Mexico, United States
Jag-lovers Forums - Jag-lovers.
