Curious, what engine in the RV
Itâs the venerable 460. Nothing spectacular, hp-wise, but massive torques.
Itâs not odd, Max - it is plain wrong. The pump should never be âdryâ as long as there is petrol in the tanks.
There is a quirky possibility. The pump delivers fuel to the fuel rail via the non-return valve; when the pump stops, the pressure in the rail reverses the valves position - blocking the fuel from the rail to retain rail pressure. At that stage, the valve opens a passage to the return hose - to âvent the pumpâ, as the book says. I never considered that seriously essential - I assumed fuel would still be filling the pump from the tanks. But I could be wrong?
Frank
xj6 85 Sov Europe (UK/NZ)
Frank
No, the pump shouldnât be running dry in any way and I canât see how. Even if there was a leak. I donât think thereâs a problem and if there was it wouldnât be the pump thatâs faulty.
A thought came to mind. The pump shoud nt be dry? Teh tank feeds the pump by gravity. It has to be wet!!!
But, perhpas it has an air bubble. And, the disconnect bleeds the air off. Teh prime is extraneous.
And, just try a boost. Add air under pressure to the tank, via the fillller capp. A form of prime, I borrpwed that from a diesel guy.
Oddiotoes in the world exst. Like the screech in my hearing aid the other day, i drove my Jeept deposit my vote. awful apparently my hearing aid was spicking up an errant signal!!!
Carl
Itâs been 2 weeks. The car has been sitting. I think she is much happier with fresh coolant and the floor is coolant free for now⌠That makes me happy!
After over 1 year the hood is finally back on. For some reason it looks like itâs lined up nicely but it is not closing well. I have to hold the hood handle in the open position to get the pins to go in. Ill have to figure this out but for now I am happy the thing finally looks like a car again. One of the rubber bumper side parts has broken out. The screw fixture ripped out of the rubber. I will see if I can get a good one of the parts car.
The way I see this could happen is if the pin id too far towards the latch and doesnât hit it on the slope, or the entire contraption isnât greased well enough.
actually let me try that. since the engine bay was painted there is no greace on that side of the sandwichâŚ
All the sliding surfaces have to be greased, also the seating surface, it wonât look so good but the paint will wear either way.
Mine latches nicely. I did some work to make sre the pin and the latch were aligned. A bit of tape over the latch. a blob of grease on the pin. Lower the bonnet til the pis just tuch the tape. Alignw ith a gentle tap with a rubber mallett.
Teh pins screw in. teh depth must be just right. that part is oure trial and error.
lastly, I give them a dab/ usually at oil change time
And I squirt some pil on the hinge pins. whether ti reaches and works, only a guess.
Just left from my college days and amy after school jb at a full service station Wash and grease fur bucks@
That easily / always happens. Iâm glad you donât have any bigger âissuesâ now.
Ps. Iâm in Germany again, I keep coming back every week now.
How do you make the hood close while holding the handle, Max.? Holding the handle does nothing to affect pin alignment, it only retracts the striker plates - and the striker springs will prevent the hood from closing even with striker plates retractedâŚ
Given Carlâs and others procedure for pin alignment, and correct length adjustment; with the weight of the bonnet when falling, the pins force the spring loaded latch plates back allowing the striker pins spring to compress. The notch in the pins allow the striker plates to close, holding the bonnet closed. Opening the hood handle open just retracts the striker plate, allowing the pin springs to pop the bonnet open - holding the handle open while closing the bonnet will just prevent the striker plate to latch the bonnet closeâŚsoâŚ?
Frank
xj6 85 Sov Europe (UKNZ)
So I had a friend help me install the hood because it is quite big and awkward job for one person. We had the side of the wings taped to prevent possible scratches. So we lined it and the fit looks pretty good to me. I never dared to just let the bonnet fall and see what happens. so if I just press it down with my hand I can only get it in my buddy pulls the handle and then it will slide in. Once it is half way in release the handle and press the bonnet down shut. the right side is worse than the left. But I will play with it some more.
The correct way to close the XJ6 bonnet is to stand in front of the car and with one hand place it mid point in the bonnet and push it down. The weight should be sufficient to latch it closed.
I do not have the struts installed so there would be more weight coming down. I figured it would be good to get everything aligned before installing them.
Thatâs also what I do.
I have no struts.
You have the spring version then
Yes.
They omitted the springs when the added the struts? Makes sense.
Yes. I have no springs. So the bonnet would free fall now if I let it go. The parts car had the spring version.
A8 in Stuttgart, drop by!
I slam the bonnet much harder than any other car, needs at least 30 cm of travel and full force, push in the middle. That or stand at the front, bonnet fully open, and lift up on the grille sharply. You know that your alignment is correct and you know that the pins will go into the latch. You didnât change anything about the latches, if it touches on the inclined parts itâll go in.
