[quote]
I had adjusted the idle again. Back down to 750 and in gear it would go down to 550 with my foot on the break. I had been working the transmission screw slowly and it was coming down to 45ish and when accelerating EXTREMELY slow it would actually shift at the 30ish that it is supposed to.
[unqote]
The box is very sensitive to pedal position, Max, as it is to cable adjustment. āAcceleratingā implies more pedal than required - to upshift at 30 kph you just need enough pedal to maintain 30ish. More pedal means later upshifts - ālight throttleā sort of means āno accelerationā.
Correct cable adjustment also means that the shifts are dead smooth/imperceptible - there should be no jerking. Main point is that with correct adjustments and everything works as they should; shifting points are spot on and and the shifting is dead smooth.
To use the cable adjustment to correct shift points at the cost of rough shifting may just mask a problem. Which is why using pressure to adjust the cable is preferableā¦
The most likely cause of your high fuel consumption is the short trips taken - and possible enthusiastic driving. The consumption usually quoted is for steady cruising, not frequent change in speed - and certainly not idling in traffic. And incorrect cable adjustments does not helpā¦
[quote]
I have no idea when it started but for a few second while breaking and going down hill I got a red Oil alert. It turned off within maybe 15 seconds.Tunes off and I was now pretty much in emergency state.
[unquote]
The oil pump pick-up is at the rear of the sump, so going downhill, or braking causes oil to surge forward. With low(ish) oil level the pump may briefly suck air, and the warning light comes on very quickly - the gaugeās response is much slowerā¦
[quote]
So I shut her off went to get a drink and figured it should be more oil after I shut her off and let her sit for a bit. When I came back I actually found less oil on the stick
[unquote]
Which is somewhat odd - oil drains back into the engine when stopped. However, it is preferable to check oil levels with the engine stopped - with the engine running it is quite possible to misread the stick levelā¦
The markings on the stick are āmin/maxā, and nominally anything in between is OK. There is no need to fill to the āmaxā mark; the xk engine very quickly burns of the top pint or two - a total wasteā¦
With an unknown engine; regular oil level checks under identical conditions, preferably engine cold/before starting. This will give a consistent reading to asses possible leaks or consumptionā¦
There is always a quandary when two indicators differ - which do you trust. The oil warning lamp nominally comes on instantly when the pressure drops below some 5 psi - the gauge lags behind.
With low idle, waiting in traffic with the engine hot, it is not unusual for the warning light to flicker vaguely. It is not alarming - at low rpms the engine doesnāt need much oil pressure, and the sensor may just be on the high sideā¦
Also, the gauge will show such low pressure under similar conditions. As Jochen suggests; it does not come amiss to verify the dash gauge with an external oil pressure gauge - just to make sure the dash gauge reads true. And of course to check for leaks as he advises - though most well used xk engines leak to some extentā¦
You did exactly right and there is no reason for worrying - your experience is par for the course! Just keep and eye on the oil level until satisfied it doesnāt drop excessively fastā¦
You may also up the idle a bit to get rid of the warning lamp flicker. Jaguar specifies a minimum pressure of 40 psi at 3000 rpms - and excessive pressure is not good either, as Jochen rightfully points outā¦
Frank
xj6 85 Sov Europe (UK/NZ)
