In reply to a message from Frank sent Mon 25 Apr 2016:
Thanks for the information here is the next update:
Removed white electrical part of the ignition switch and
cleaned the contacts. Then realized that there is an inner
white part with springs and 3 more contacts so cleaned that too.
Tried to put it all back together whist standing on my head
under the dash and found that it would not re clip
positively onto the metal portion of the ignition switch
assembly. (Some parts photos seem to show a black rubber
round part around the white ones but there was nothing like
that when I got to the switch on mine.)
Temporarily used some tie wraps to hold it in position but
found that I still had to reach under and hold the two
portions of the switch contacts together to get any results.
Those results were again disappointing. No spark and
probably no fuel pump action either. Cranks though.
Powering up the white circuit by jumwiring from batt pos to any white
connection will bypass this function of the ign switch, Brian…
But it is important to regard all this as possibly two different issues;
lack of white power (an ign switch problem), and lack of sparking which
may have other causes.
Jumpwiring batt pos directly to coil pos will power up the ignition system -
which is a separate subsystem requiring no inputs from other management
systems. Cranking the engine should then produce sparks irrespective of ign
key state. If there is still no sparking, the ign system should be addressed
as a separate problem. You should also test for sparking using the coil
centre lead - to eliminate a distributor malady…
The simplest test is then to connect a test lamp between coil neg and
ground - the lamp should be fully lit. While cranking the test lamp should
dim and flicker - implying that the ign amp is operating. However, it
doesn’t guarantee that the ign am is fully functional - it may still
malfunction, failing to trigger sparking. ‘No light’ implies a coil fault -
or a ground short from coil neg…
While in the area; there should be two white wires at coil pos - one from
the ign key, and one to the ign amp. At coil neg there should be 3 wires;
one black/white to the ign amp, one black/white to the ECU and one
white/slate blue to the tacho. No other way of connecting is
permissible…
Frank
xj6 85 Sov Europe (UK/NZ)
I seem to be faced with replacing the ignition switch $$$
and then most likely ringing out the white wire circuit from
there up to the coil.-----Original Message-----
Sent: Tuesday, April 26, 2016 1:57 PM
To: xj@jag-lovers.org
Subject: Re: [xj] No Spark 86 XJ-6
