Hello all,
I hope someone can help me out with the following:
With the A/C belt removed the A/C idler runs smoothly but makes a horrible
“rolling noise”. It sounds like the bearing lost all it’s grease! There is
no play but I won’t be surprised if the belt starts smoking soon!
- How can I put some grease in the bearing? … if it is possible…
- How can I remove the clutch to acces the bearing? Can I just remove the
big nut from the front? Can I leave the compressor in place? - How can I remove the old bearing? With a hydraulic press?
- Can this job be done without specific GM 6 tools? I saw all the McGyver
episodes… no special tools needed…
Greetings
Walter Arkesteijn - Daimler Double Six SII 1974===================================================
FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/xjfaq.html
