Listers,
Because I noticed a very slight oil leak that appears
to surround my oil fill cap, I purchased the O-ring
part #C42511 from my local dealer. When I pried out
the old ring, it appears to be made of a hard plastic.
The new ring is soft rubber. Is the change in
composition a result of heat and age or do I use the
new ring in addition to the old plastic inset ring?
Many thanks.
Bruce Carson
86 XJ6 Series III
66000 miles__________________________________________________
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger http://phonecard.yahoo.com/
The hard plastic is what the rubber changes to after 15 years bathed in hot
engine oil. Dig it out and put the new one in.
A neoprene ring from the local plumbing supply works well too.–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
