For a while now my overdrive has been inop. When I turn the switch
on I get the familiar solenoid click, but no drop in revs.
If I lift off then the revs drop, but rise back up to the direct
4th speed as soon as I reapply some throttle.
I’ll be checking it out this weekend with a bit of luck, but I seem
to recall someone else (Arnoud perhaps?) having the same problem at
a similar time (i.e. a month or two back). Anyone had a similar
failure and tracked down the cause?
Cheers,–
Rob Hod '73 Daimler Sovereign MOD
