Spent some time today doing the Gardner, a/c compressor cutoff and
aux-fan-on-with-compressor mods. (Jag-lovers is great!) While in the
process of wiring in the diode for the aux fan mod, I noticed what looks
sort of like an in-line fuse holder for modern flat fuses, only bigger.
It has a green/brown wire and the green compressor wire as inputs, and has
plastic clips to retain the item which is plugged into it.
The part is still plugged into mine, but the plastic cover over it is 60%
missing, leaving the fuse(?) exposed to the elements. The holder itself
is fine, it’s just the item being held which is broken.
Is this in fact the (50A?) a/c compressor fuse? And (either way), can I
replace it with an OTC part, or must this item be prescribed by the Lords
of Lucas?
(The a/c works great, but…)–
- bill
'84 XJ6 (Julia)
