[xj] overrun valve
Hello folks,
Thanks for all the help extended from all members.
My car suddenly started to have rough idle and dies when the AC is
on while in gear. I replaced the spark plugs, intake manifold
hoses, fuel filter and pump with no success! I dismantled the
throttle body and overrun valve for cleaning and checking for
leaks. I am not sure about the correct installation of the overrun
valve, does the spring go into the manifold as seen in the parts
catalogue or the into the housing?
When I remove and block the vacum line to the advance mechanism of
the distributor, the idle gets worse!? Any thoughts?
Regards,–
Jomo, XJ6 1986
Abu Dhabi, United Arab Emirates
G’day everyone,quick question which direction does the over
run valve go? is it spring up or down?
hopefully up cause that’s the way I put it back in. I coulda
sworn that it came out that way but
I stumbled across a picture in the Haynes book and it shows
the spring faceing down.
thanks!!!–
jeff 1985 xj6 III
cumberland / md, United States
This has come up before. As I recall, whatever is illustrated in the manuals
is incorrect, so if the manaul shows it “spring down” then the correct
orientation is “spring up”
Doug Dwyer
Longview, Washington USA
1987 XJ6 Ser III
1988 XJS V12 CoupeFrom: “skywlkr5” ninhalo1973@yahoo.com
thanks!!!
In reply to a message from Doug Dwyer sent Wed 31 May 2006:
Thank you Doug.
I guess if one relied on manuals alone they can get into a
world of hurt.–
is incorrect, so if the manaul shows it ‘‘spring down’’ then the correct
orientation is ‘‘spring up’’
jeff 1985 xj6 III
G’day Doug and Jeff,
I just happen to have mine removed at the moment. All the
manuals and the parts catalogue show it wrong way up. This is really a
non-issue though 'cos it can’t be fitted upsde down, the hole in the
manifold is smaller than the spring diameter.
regards,
John Hudson
Brisbane Australia
71 SI XJ6, 85 SIII XJ6----- Original Message -----
To: xj@jag-lovers.org
Sent: Wednesday, May 31, 2006 11:50 PM
Subject: Re: [xj] overrun valve
manuals is incorrect, so if the manaul shows it “spring down” then the
correct orientation is “spring up”
Doug Dwyer
1987 XJ6 Ser III
1988 XJS V12 Coupe
thanks!!!
Yeah, I’ve got one on the bench right now and there’s only one way
mine can go in - spring up. Which is almost counterintuitive…??–
Doug Dwyer
Ted Macklin/'85 XJ6SIII
I sorta thought so but its been so long since I’ve had mine off that I
didn’t have the guts to say it :slight_smile:
Doug Dwyer
1987 XJ6 Ser III
1988 XJS V12 CoupeFrom: “John Hudson” huddo@bigpond.net.au
This is really a non-issue though 'cos it can’t be fitted upsde down, the
hole in the manifold is smaller than the spring diameter.
regards,
In reply to a message from John Hudson sent Wed 31 May 2006:
Thanks John, that is what I thought but my spring actually
fit in either direction. perhaps it’s not an original. by
looking at the design I thought logically the part would be
useless if the spring went into the manifold instead of the
housing.
speaking of which… is there a certian way to set the
adjuster screw? kinda like tighten it down then back it off
2 turns? I can’t seem to find anything in the Haynes about it.
thanks–
jeff 1985 xj6 III
AFAIK, it is not intended to be routinely adjusted but I’d think tightening
it by one or two turns to compensate for loss of tension couldn’t hurt.
Doug Dwyer
1987 XJ6 Ser III
Factory manual doesn’t tell you anything either. Seems it was ‘factory set
and forget’. I tightened the screw on mine by several turns and the vacuum
at idle went up, which seemed like a good thing to me.
regards,
John Hudson
Brisbane Australia
tightening it by one or two turns to compensate for loss of tension
couldn’t hurt.
Doug Dwyer
Hmmm. Several turns ?
I may have to so some experimenting…on my V12.
Doug Dwyer
1987 XJ6 Ser III
set and forget’. I tightened the screw on mine by several turns and
the vacuum at idle went up, which seemed like a good thing to me.
Hm, John - the overrun valve should be firmly closed at idle
vacuum…it’s only supposed to allow extra air into the manifold at
high overrun vacuum. There are some interesting bi-effects from a faulty
overrun valve…:slight_smile:
Frank
xj6 85 Sov Europe (UK/NZ)===================================================
