cadjag wrote:
As to the Petronix. If the car ran before it on the Jaguar system,
I would go back. The Petronix is a step up from points, but so is
the Jaguar/GM so little is gained by a switch unless the GM
amplifier or other component is flakey.If you go with the petronix, the amplifier is not needed as it is
redundant. And, I would follow the Petronix instructions on coil
and ballast. Remember, the base reason for a ballast is point
protection against higher voltage, so the Petronix folks believe
their unit needs that same protection.
Which is the bewildering part, Carl - our CE has no points to protect.
And with the ign amp redundant - where does the Pertronix get its firing
data…?
Frank
xj6 85 Sov Europe (UK/NZ)>All that is just the reasoning of a non Jaguar electrical genius or
any other kind.
Happy New Year
Good Luck.
Carl
Thanks for the input. I picked up a fuel pressure gauge at
Sears (Made in China… grrr). I’m getting 41 psi at as the
line connects to the fuel rail (I installed a permanent
brass T fitting for testing) in the cranking and also run
ignition switch position, so the fuel seems good. A fuel
pressure gauge is a nice addition to my toolbox, either way.–
Carl Hutchins
Walnut Creek, California, United States
–Support Jag-lovers - Donate at http://www.jag-lovers.org/donate04.php –===================================================
Archives: Jag-lovers Forums - Jag-loversTo remove yourself from this list, go to Jag-lovers Forums - Jag-lovers.
