In reply to a message from Dwomby sent Wed 31 Dec 2014:
David!
Thanks so much on getting back to me so quick.
I’m having a problem keeping my air. on heat, I can
hear the servo going back and forth, sounds like its
searching.
Usually, if the AC amp fails, Walter, the servo doesn’t move at all…
A preliminary test is to verify, with a thermometer, that the system
operates correctly, but your sense of hot and cold differ from the system’s
readings…
Frank
xj6 85 Sov Europe (UK/NZ)
I sometimes turns it to cool when I need heat.
Where you the person that had the info. on this site for
an amplifier that works?
Would you have some more info. on that supplier?
The original message included these comments:-----Original Message-----
Sent: Thursday, January 01, 2015 10:31 AM
To: xj@jag-lovers.org
Subject: Re: [xj] purchase of new air cond. amplifier
I bought one of those ‘shotgun’ ones a few years back from a
supplier in Australia. It works perfectly for me in my 78.
Walter Schuster 78XJ6 FI Ser.II
Albuquerque/New Mexico, United States
http://www.jag-lovers.org/cgi-bin/majordomo.
