[xj] Radio stays on when ignition turned off?
Hi
I am a regular reader with regular Jag woes !
I swear my XJ6 1986 is possessed.
Just lately after I had the heater core replaced I have noticed that the
radio will stay on after I have turned off the ignition fully. Is this a
grounding problem or what ?
Morgan O’Brien Lubbock West Texas
Morgan O’Brien===================================================
FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/xjfaq.html
Most likley a bad diode in the alt. allowing power to feed back when the
ign switch is off. You can do a quick check, by removing the small wire
from the alt. when the radio is playing and the ign. switch is off. If
radio quits then you have found your problem.
Chad Bolles
803 798 3044
FAX 803 79i8 4512
Morgan & Clara O’Brien wrote:>
Hi
I suppose another possibility might be that the wiring became a wee bit
cobbled up on reassembly of the dashboard pieces so that the radio is now
wired to a constant voltage source. This would probably be most likely if it
has an aftermarket radio with a slew of sliced in connections instead of the
plug-in OEM connections.
Or, perhaps, a problem with the circuit (internal or external) which
supplies a constant voltage for the “memory” function of the radio ?
I like Chad’s idea.
Doug Dwyer
Longview, Washington USA
a----- Original Message -----
