On the weekend I finally got the rebuilt final drive back into the car.
Only took two years. A long time ago I replaced the master cylinder and
I noticed that on the Brake fluid reservoir that it had only one rubber
grommet. Before I hook up the Brake lines I need to know if there should
be two grommets. As this is an 82 XJ12 my Haynes manual does not show
this very well. Next up the tear down of the V12
Thanks in advance
Chuck Mauch Vancouver Canada
82 XJ12 long term project
84 XJ-S Daily Driver
There should be two. Not sold separately, but they’re part of Jaguar
seals kit AAU6838 - the master cylinder rebuild kit.
Henry Fok
XJ Web Admin
Cum catapultae proscriptae erunt tum soli proscripti catapultas habebunt------------------------------------------------------------------------
Windows XP. Looks like a duck. Walks like a duck. Quacks like a duck.
Too bad it’s a decoy.
In case you want to try… I used two O-rings of good material around the
bases of the two spigots on the reservoir of our 86 and it’s working just
fine. You’ll need to shim up with additional neoprene washers, if the pins
slide easily into the master – you should have it so you need a few pounds of
pressure down onto the reservoir in order to get the pins to slide through.–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
