Dick, if you had worked at BL, you would’ve been fired so quickly! :]–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
Vand116@AOL.COM wrote:
Hello Len,
Went one step further. Drilled out the spigot in the thermostat
cover and threaded the hole with 1/8" NPT and used a stainless
steel hose spigot. Also replace the 1/4" tubing with stainless steel.
And the heater pipe, and the hose bibs on the waterpump, and
the one at the rear of the water rail… Two more 1/4" hose spigots
in the water rail and the tube to the atmospheric tank to go.Dick Vandermeyden
San Carlos, California
