Dr. Andrachuck and listers
My long awaited CIBIE fog lights just came in . In preparation for
installation I read
Dr. Andrachuck’s good article in the “XJ FAQ"Finding the electrical leads
took two minutes. Enabeling the head light/fog light switch took up a
maximum of 5 minutes. Now we come to the problem. How do I mount the lights
to the car.From looking a a number of picktures in various publications, it
looks to me that the centerline of the fog lamps should line up very close to
or just inboard of the centerline of the high beam head lights. Can anyone
confirm this observation? My fog lamps came supplied with two mounting
brackets, parts numbers BAC 2704 and BAC 2705 as seen in the green parts
book. The end of the mounting bracket that is intended to be attached to the
car has two 1/2 " holes . After having spent a half hour under the front of
the car I can’t find any place to mount these brackets .Dr. Androchuck , in
your article you say “A hole must be drilled through the aluminum support
bar”. The bracket has mounting holes for two 1/2” bolts why only drill one
hole ? Where and what is this aluminum support bar ? What does it suppotr
what shape is it where is it located. The only thing that I can find in the
front of the car that is made of aluminum is the bumper itsself.
Any help that anyone can give me will be greatly appreciated.
Regards, Paul Van Dongen
1985 XJ6 84K miles Cobalt blue and Isis===================================================
FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/xjfaq.html
