Jim,
It helps clean the intake tract and the valve stem areas in a
sort of shock mode. You get the same effect over time by dousing the fuel
supply, but the “shock” cleaning has on numerous occasions straightened out
bad idle problems and restored some of the “snap” that precipitated the need
for it to begin with. I am fortunate to have a spiffy little cap and valve
mechanism that allows me to meter it carefully without fear of stalling the
car while it runs through. GM’s top engine cleaner works on the basis of
admitting large quantitys of cleaner into the engine specifically to stall
it. Then you let it sit for a half hour and run the thing down the road to
clean it out the rest of the way.
BTW, NEVER do this inside a building! It stinks something awful,
and I’m sure breathing the stuff in close quarters is hazardous.
Cheers,
Jeb===================================================
To remove yourself from this list, go to http://www.jag-lovers.org/cgi-bin/majordomo
Hi Gang,
Not that Jeb’s advice needs any reinforcement from me but…he is most
certainly correct about the hazardous nature of GM’s “Top Engine
Cleaner”…it REALLY works and it’s REALLY hazardous ! Please be careful.
One side benefit, though, is that using this stuff in a mosquito-ridden area
will definitely take care of the problem for awhile—mosquitoes, that is !
Doug Dwyer
Longview, Washington USA
snipped
awful,----- Original Message -----
To remove yourself from this list, go to Jag-lovers Forums - Jag-lovers
