[xj] re problems starting
Hi Phill,
To see if it is the plug wires have a look under the hood on a damp dark
night while someone cranks it over. Bad wires will usually show arcing all
over the place, and still one would expect some sort of firing on some
cylinders.
Like Gregory said , listen for the fuel pump to run when first turning the
ignition to the on position.
You could also take a hose held to your ear and see if you can hear the
injectors clicking while it is cranked in this won’t start mode.
These things could narrow down your problem.
Russell===================================================
