Aaron, hi, speaking of horns.
I have a s1, and my horn wiring is all chopped up by the prior owner. when
you get your car back can you tell me which relay is the horn relay ? and
maybe how to identify it ? I have 2 in the passenger side fender firewall,
one is properly mounted and looks to be something like the ignition relay.
the other is mounted more forward below the coil ballast resistor on a real
funny looking bracket, it may not be the original jag relay or bracket is my
guess.
thanks, Ted Stowe-----Original Message-----
Sent: Friday, November 05, 1999 7:52 PM
To: xj@jag-lovers.org
Subject: [xj] Re: horns
The horns on Series One cars, were mounted on the front subframe, a bit
below the engine mounts. (My car is in being repaired, so I can’t have a
good look and say EXACTLY where). From memory, Seies Three subframes still
have the mounts/holes for the horns.
Its not a BAD location… they don’t get killed in an accident, and don’t
get too damaged by the elements. You can still hear them too …
Have fun!
Aaron Goldman
Brisbane Australia
Get Your Private, Free Email at http://www.hotmail.com
NOTICE: This communication may contain privileged or other confidential information. If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this email in error, and delete the copy you received. Thank you.
