Here is a dumb question. How do you remove the rear door
mounted ashtray? Do you remove the whole housing or just the
pivoting lid portion. I don’t want to break or tear anything?
Thanks
John
87 XJ6 SIII–
jd1963
Los Angeles, CA, United States
Very easy: open the ashtray; press down on that tang now visible at the top.
The ashtray now comes out and you have access to that panel mounting screw.
Gregory,
Victoria, Canada
1966 Mark 2 3.8 (Pale Primrose)
1992 Series III V12 Vanden Plas (Black Cherry)
2002 X-Type 5 sp. manual (Anthracite)
2004 XJ8 4.2 (Ebony)-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org] On Behalf Of
jd1963
Sent: June-10-09 6:57 AM
To: xj@jag-lovers.org
Subject: [xj] Rear door panel removal
