the rear shocks are fairly straight foward to remove. you only need to put
the rear
up on jack stands and remove the wheels. access isnt to much of a problem,
the only
real pesty part is removing the old springs from the old dampers to retrieve
the
collets to use when assembling the new shocks and springs, unless you
brought them
as well, btw, the procedure is in the ROM and is probably one of the few
that dont
start with the line ‘step 1. remove the engine…’ :)).
regards
darrin----- Original Message -----
To: xj@jag-lovers.org
Sent: Monday, April 23, 2001 5:31 PM
Subject: [xj] Rear suspension
When on the issue, I am planning on replacing the rear road springs and
dampers, but I don’t feel like shedding the entire subframe unit.
Does any of you listers have experience in doing this with the cage in
situ, or slightly lowered to easier get to the top bolts?
Best regards
Baard Th Hesvik
Jaguar XJ6 4.2 litre Series I 1972 SWB - Dark Blue/Grey
Best regards
Baard Th Hesvik
Hello Baard
If I had the choice I’ld take the cage out . It is an relative
simple operation I had mine out in about an hour and a half
this being the first time for me to do it.
succes Jeroen
Jeroen van Gool
Daimler souvereign 4.2 1970
Range Rover 3.5 1971
Jeroen replied:
Unless you’re planning on doing more than merely changing the
rear shocks and springs, dropping the cage is a waste of time.
In the hour and a half taken to drop the cage, I’d have had the
shocks and springs in and out, without breaking a sweat. Dropping
the cage is a job best saved for when you’re planning a full
overhaul, not at all necessary for the simple job asked about.
Does any of you listers have experience in doing this with the cage in situ,
Baard,
I just did this procedure a couple week ago on my 86 Vdp. Series 3. No need
to drop the rear sub. Just remove the wheels and have a grouping of 11/16"
sockets, extensions and wrenches. The first side took about an hour, and the
second side took 20 minutes. This does not include the time to put new
springs on new shocks. I don't know if the S1 is different, but it should be
very similar and it made a huge difference in ride and height of body.
Good Luck
