A few months ago (back in April) I posted a question
regarding the Reverse Lights wires, and their locations.
On the XJ6, Fuse 4 (a green wire) supplies the voltage to
the circuit – a Green wire with a Brown Tracer
(Green/Brown) runs from the transmission to the lights,
which are then individual grounded.
However, I’m not sure which Green/Brown wire I need to
identify – I’m under the center console right now, where
the shifter tower was – there is a pigtail which connects
to the larger harness on the driver’s side of the slope
which has a couple other wires, in addition to a Green/Brown
wire – however, there are a couple other Green/brown wires
in the same area, and don’t seem to be connected.
Sooo, my question is where can I find where the Green/brown
wire which runs to the reverse lights? I’m looking in the
trans tunnel… are there any other wires next to it that
could help me locate it?–
Tyler Werrin, 1984 Jaguar XJ6 Series 3 w/ 1994 Camaro t56
In reply to a message from tylerwerrin sent Wed 3 Aug 2011:
Green/brown is definitely the switched supply to the reverse
lights, so any green/brown used for a different function in
the same harness would be light green/brown.–
In reply to a message from sparx sent Wed 3 Aug 2011:
I found the wires that work – it is part of the pigtail which
connects to the tower itself – there is a green wire and a
green/brown wire. Reverse lights are now connected to the T56
and work perfectly.–
