I’ve just acquired an inexpensive 84 XJ6 VDP to use as a daily driver, and
have an odd situation with how the car runs. When I first start the car in
the mornings (it’s cold here), it fires up immediately, and runs great…no
misfire, very quick and responsive. However, the car runs cold, it never
gets above 80 degrees. The weird thing is, the first time I shut the car
off, whether after a long run or a short run, it still starts right up, but
then misfires/stutters on acceleration. When I get up to speed and hold it
steady, even at 70mph, it’s fine, but idling it misfires, and punching it,
it misfires. Not horribly, but enough stutter to annoy the hell out of
me. Once I get it up to speed it’s very smooth.
The next time I start the car, it could be perfectly fine…there’s not
really a pattern to it, it just seems to happen sometimes. One consistent
thing is that the car definitely runs too cool, between 70 and 80, which
probably means a t-stat is stuck open. Would that cause a car to misfire?
Thanks as always.
Nick===================================================
