Hi Bob,
I’m not sure what to think of those results. A burned exhaust valve
would NOT be expected to allow as high as 80 PSIG wet compression, let
alone 145 dry. I can’t account for why two adjacent cylinders would
have bad rings or piston damage. Both low compression cylinders are
adjacent (4B & 5B), suggesting a blown head gasket at the sealing rings
between those two cylinders, BUT one would expect essentially equal
compression on the two cylinders if that were the case, and you would
also be likely to hear a “poppa - poppa” noise from compression/power
stroke blowing between cylinders. ALL A bank cylinders are OK, so if
what is described below doesn’t fix the problem, pulling the B bank
head probably would.
I assume you don’t have any clacking sound, indicative of dropped valve
seat? How is your idle speed, and do you have an intake manifold
gasket leak? How long have you had the car, and if it has any known
history of overheating, when did that occur? Have you regularly taken
it to 6K RPM to blow out the carbon, or do you drive almost exclusively
short distance & low speed & RPM trips?
If the latter, you may have carbon-fouled intakes on 4B & 5B which may
be improved by using injector/fuel system cleaner and doing some
Italian tuneups (1st gear forays to 6k RPM). I would certainly try two
applications of injector cleaner and daily Italian tuneups for a week
or two, and then retest (wet --squirt of oil in each cylinder before
testing that cylinder). With luck, your problem is carbon-fouled
intake valves, which can be significantly improved as described above,
without pulling the head and cleaning/lapping the valves.
85 & 89 XJ-S Coupes; 89 XJ40 VDP-----Original Message-----
I finally got down to a proper test and the results were not good
left bank 1,210,2 208,3 212,4 60,5 145,6 205,the rigt bank was a
solid 210 +/- 5 I did add oil to the #4 and the compression came up
to 85
What do you guys think bad rings or piston or head gasket I hate
the thought of pulling the engine unless I can find some help on
the north west coast
Thanks Bob
