Fuel pressure was about 44 with the car not running and 37 after I started
it. I don’t know about full throttle.
I changed the oil.
After installing the old ECU (forgot to ground it), only 1/2 the injectors
were firing. It was running this way for a little bit and then (randomly)
started to run normal-then bad again.
I am now rebuilding the wiring harness-just to make sure that isn’t the
problem.
ECU PINS:1,3,18,17,`16,15
34,35,23,25 are grounded (key off)
Most of these are supposed to be grounded, but I’m not sure about pins
3,18,and 15. Are they supposed ot be grounded? Can anyone confirm so?
The problem went from bad to worse. Seems to only be running off the right
bank-I measured this with a stethoscope. Maybe when I forgot to ground the
ECU, I fried the transistors? I think I might be able to rebuild my ECU
(from 2 of them) if it weren’t for the fact that I can’t find the part
numbers in the ECU.
There are 6 heat sinked-transistor-looking chips inside the 6CU. They all
say “RCA 510” and something like 17434A. I’ve looked everywhere-even
outdated chip catalogues: 1973,1976,1979,1984, 1993. Seems that most things
close to those data numbers are transisitors. Does anyone know where to
find them? I am desperate.
I would even reverse engineer the characateristics of the chips, but…
- I don’t know for certain they are a transisitor.
- I can’t interpret any definitive characteristics on the curve tracer-
something turns on, but there doesn’t seem to be anything else interesting
happening-couldn measure a collector current.
Kirby mentions fried transistos in his book, but I still don’t see whih ones
he was refering to.
Any help would be greatly appreciated.
Rob
I think an IAT is an Intake Air Transducer. The little gizmo
on the port side air intake trumpet with a couple of wires on it.
Oil wise?. I think its time for an oil/filter change. Don’t think
you will have caused any damage by fuel/oil contamination unless a
fountain of gas came out when you removed the dipstick. Just call
what’s in it flushing oil. If this runs lean have you had plug
problems what’s the plug colour after a thrash also give us an idea
of how lean is it like is there a big flat spot or something.
What’s the exhaust colour inside the tail pipes. How much fuel
pressure are we at in the rail at wide open throttle.
Regards Mark–
Bassmec, XJS V12 1977 Coupe
Ipswich, Suffolk., United Kingdom
