In reply to a message from Jags+30jugs sent Tue 25 Mar 2008:
So now I’m confused, which is a perfectly normal situation for me
Should I install the jumper or not? I’m in Southern California, and
premium gas is 91 octane; I just read that the UK calculates octane
ratings differently, there’s approximately a 4-point difference, so
95 octane UK would be 91 US, which would imply that I should put
the jumper back in IF the 95/91 octane settings [I believe from
Jaguar] is talking about UK-calculated octane values.
I guess if I do need to reconnect the jumper, I’m back to square
one with my fuel consumption. Ed seems to think it’s at pre-HE
levels, so that’s not at all good.
I did have a suspicion this morning that the car seemed a little
more sluggish than before, I guess that can be explained if my
timing’s retarded incorrectly.
Regarding the inlet air temp switch, I’m pretty sure my normal
operating temperature in LA is going to be in excess of the 75C
tripping point of the switch. You say you’ve disconnected yours and
the engine is running cooler, but I don’t get any real problems
with overheating; if it’s a sweltering day (100+) and I’m stuck in
traffic, the temp gauge does creep towards the high side (probably
3/4 to the red), but it comes down to center within a very short
time once I’m moving again.
If the inlet air temp switch is there precisely for the reason to
retard the timing if the underhood temp exceeds 75C, would that
imply that if I’m sucking air that would normally be between 70F
and 110F, the switch is tripping too early? It seems odd that if
it’s there to check the underhood temperature, it’s measuring the
air temperature inside the intake which can be skewed by
temperature variations from outside. I’d guess that I’m almost
always running with the timing retarded if this switch is
functioning as designed. If my temp gauge is pretty well rock-
steady ‘‘N’’ under most circumstances, then I don’t need this switch
messing around with the timing, so I guess I should go ahead and
disconnect it?
I’ve got some other issues to deal with (I’ve got a surging idle
problem which I think I now have the information to track down and
fix) which may be contributing to the poor fuel economy depending
on what the eventual cause turns out to be. I’ll keep you posted.
Thanks for the help so far.–
The strategy jumper is supposed to be installed for normal high
octane ops. This jumper is in series with the idle switch. If the
'92 XJS V12 Convertible, '95 XJR, '00 Mercedes Benz S500
