Gordan Bobic wrote:
I was talking about stiffening up the radius arm bushes. Putting
hard bushes on the radius arms, or turning the standard ones
through 90 degrees will only lead to the top subframe mounts
failing quicker.
I kinda doubt it. Seems to me stiffer bushings, or turning the
standard forward bushings 90 degrees, will help hold the subframe
more securely and apply less stress on the subframe mounts.
Not at all. Think about how the components are arranged. The lower
whishbones have to move up and down - that’s kind of fundamental to
the suspension. As they do, they are moved forward and backward by the
fact that the radius arm is anchored to them, and is describing the
arc. The distance between the whishbone and the radius arm anchoring
point is L * cos(A), where A is the angle the the radius arm, and L is
the length of the radius arm.
Either the radius arm bushes or the subframe mounts have to give.
All true. However, it is my suspicion that the subframe mount flex
due to the arc of the radius arm is minor compared to the subframe
mount flex that occurs when you drop the hammer in 1st gear. To my
knowledge, everyone that’s had issues with the subframe mounts
reported that they failed when doing hole shots, not when the car was
jacked up (which is when the arc of the radius arm does its worst).
Since stiffening the bushings at either end of the radius arm will
reduce the amount of subframe motion due to hammering the throttle in
low gear, I suggest it would reduce the stresses on the subframe
mounts, not increase them.
Stronger anti-roll bar will spread the load between the two sides,
which may or may not make this worse.
I dunno what load will be spread between the two sides. Without the
anti-sway bar, the car leaning may stress the subframe mounts on one
side in compression and the mounts on the other side in tension, and
the anti-roll bar would be expected to reduce both stresses.
Not quite. The radius arms make the subframe twist horizontally when
vertical twisting (i.e. car leaning into a corner) is applied.
Since the suspension travel is at a different extension on each side,
the radius arm on one side is pulling the subframe farther forward
than the radius arm on the other side, distorting the subframe
mounts. Yeah, I see that. But adding an anti-roll bar would reduce
it.
Basically, it’s transferring some of the anti-roll stress from the
weak subframe mounts to the rugged anti-roll bar mounts.
Sort of, but in that case you should probably waste less time with
anti-roll bars and start by replacing the subframe mounts with solid
steel brackets, and get rid of the radius arms all together.
Not sure what this had to do with the point about the anti-roll
stress moving to the anti-roll bar mounts.
Of course, that lockdown (and simplification) of the Jaguar IRS is
exactly what the Cobra guys do. It does make a fundamental
difference in the suspension geometry, taking it from having entirely
too much rear-end steering to having none at all.
If the
idea is to restrict suspension movement, bigger anti-roll bars while
all those rubber mounts are there are a bit like polishing the
silverware on the Titanic.
I think that was my point at the beginning of this discussion. I
found the OEM 9/16" bar did just what I wanted done, but if you’re
installing that ADDCO monster, I’d think a full set of poly bushings
all around – front and back – would be in order.
