Here’s one for the Aussies. What alternators have you used
to replace your Lucas 75Amp units, and with what success?
I’m looking for a readily available alt to upgrade to.
Thanks in advance,
Gav Fisher–
Newcastle, Australia '82 Daim Sov SIII, '86 XJ-S V12 HE
I use a Bosch 130A out of a SAAB 9000.
I am not sure if it will readily mount in the original position.
Mine is mounted where the air pump used to reside.
Ed Ward,
1985 XJ-SC,
Melbourne, Australia-
In reply to a message from Gav Fisher sent Sat 24 Feb 2007:
gav -
talk to h&h in melb
they do a 115a bosche from the xj40 for not too much
i actually run 2 alternators on my double six; the second one
is from a ford econovan(!) & is a bolt-up to the air pump
bracketry; just 1 washer needed for shimming–
77 daimler double six vanden plas/91 jaguar xjs convertible
sydney/nsw, Australia
Gav try your local Holden dealer and get a 120amp
alternator off one of the late model holdens,change the
front pulley from serpentine belt to V belt and should bolt
straight up to air pump fittings and your world will be a
brighter place.
Ces
Brisbane–
Do you have a part number or the model & year Holden that the alternator you
are suggesting is from? This will help those of us down under to actually
source the correct alternator.
alternator off one of the late model holdens,change the front pulley from
serpentine belt to V belt and should bolt straight up to air pump fittings
and your world will be a brighter place.
Ces
Brisbane
