[xj-s] aux fan relay
re: craig sawyers. thanks for the info on the relay. my brother rebuilt
it to ur specs. what i need now is a hint as to what goes where. wires
as follows. double lt.green/ gre-neutral/ double-green-brown/ lt green/
black-green. relay has 5 pins numbered…thanks craig…michael 85 xjs
My wiring diagram is ambiguous here. The blue “relay” mounted on the LHS
inner wing is in fact a diode pack. What I’ll do is find out what goes
where from my brother in law, who has an XJS. On a SIII saloon (sedan)
which I have, the diodes are wired into the harness (yuk).
Craig> -----Original Message-----
From: owner-xj-s@jag-lovers.org [mailto:owner-xj-s@jag-lovers.org]On
Behalf Of MichaelBucklew
Sent: 16 September 1998 00:27
To: xj-s@jag-lovers.org
Subject: [xj-s] aux fan relay
brother rebuilt
lt green/
OK Michael, here’s what I have from the broth-in-law:
Pin1 double green/brown (could be green/red)
Pin2 double light green
Pin3 single green/neutral (could be green/pink)
Pin4 single light green
Pin5 single black/green
Good luck
Craig Sawyers> -----Original Message-----
Behalf Of Craig Sawyers
Sent: 16 September 1998 08:50
To: mrbuck@sunherald.infi.net; xj-s@jag-lovers.org
Subject: RE: [xj-s] aux fan relay
mounted on the LHS
what goes
saloon (sedan)
Craig
brother rebuilt
where. wires
lt green/
