First, It is a 1992 XJS, Coupe. When I tried to open boot, I heard a loud ‘snapping’ sound and now boot push lever will not open boot. There appears to be no way to take anything other than the license plate light assemblies off to get boot open to repair push lever. Which I did - but to no avail. Key, of course, just locks or unlocks, the push lever opens boot. Is it possible to enter boot from behind seat? Or does someone out there know a way in? Luckily, I just put in a new battery.
Skip Fritz
1992 XJS, Coupe
1995 XJS, Coupe 6.0
1979 Silver Shadow
In reply to a message from Ed Sowell sent Sat 30 Mar 2013:
When I changed my license plate I found that my boot lid had been
drilled by a PO, as you mention. It came in handy later, when the
lock broke, as it was the only way to get into the boot to fix the
lock!!
My PO drilled several holes to find the right spot. Once you find
it, all it takes is a screwdriver to pop it open.–
John. '95 XJS 6.0L convertible. Southlake, TX
