In reply to a message from jstjagguy sent Sat 18 May 2013:
''I turned the meter to the ohms function and held the test
leads apart and got a reading of 1 ohms … ‘’
I don’t know how it can do that with the test leads not contacting
each other. It should not be reading any ohms or infinite ohms. I
would take it back to where you bought it and have them explain how
it can read 1 ohm when the leads are not contacting each other - to
me, that’s a malfunction of the meter.
Before I trusted the readings of your meter, I would want to find
out why it reads 1 ohm with the leads not contacting anything
and/or not touching together.
‘‘then I put the test leads directly together and got a reading of 0
ohms.’’
That would be correct.
''Then I put the test leads on the 2 male pins directly on the
main valve and got a reading of 0 ohms. So it sounds like
the solenoid coil is shorted.’’
Are you sure that each lead was only touching a pin each of the
main valve and not touching any of the metal around the pins? If
the leads were only touching 1 pin each and not any of the
surrounding metal and you got ‘‘0’’ Ohms, then that indicates a short
of the main valve solenoid coil and it is a throw away - if you
trust your meter readings.
''Could you explain the significance of getting a 0 ohm
reading instead of a 2-5 ohm reading in the case of the main
valve or a 0.8-1.4 ohm reading in the case of the RR sensor?
What does the 0 ohm reading tell me from a physical
standpoint…’’
‘‘0’’ ohms means there is no or little resistance, or a short (the
electricity is short cutting the circuit and not flowing thru the
intended path so the circuit (solenoid) will not work. Even short
lengths of wire and circuits have some value of resistance such as
the 0.8-1.4 ohms you expect to see for the wheel sensors, or the 2-
5 ohm for the main valve. When you test a wire or circuit for
continuity (no breaks) you still expect to see some small value of
resistance. Some of the readings are subjective and you need to
have some knowledge of the circuit.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
