In reply to a message from gbalthropxjs@aol.com sent Thu 29 May 2008:
The car has no power what so ever although it tick over
perfectly.
I have checked the distributer output all leads fine. I have
checked the injectors listening through a screwdriver all
ticking
away.
The problem has been solved finally. It was the wiring loom
to two of the injectors. The insulation had broken down
causing a short that in turn prevented the A bank receiving
fuel. Thanks for everyones adviceFrom: Ansam
Ansam
