I have an 87 XJS that has been having starting problems. I
am fairly sure the crank position sensor needs to be
replaced.
Can someone tell where it is located? I thought it was near
the water pump but I have not been able to find it.–
Dr E. A. James
In reply to a message from NANAKI sent Tue 9 Feb 2016:
'87 v12 should have lucas ignition. no crank position sensor until
marelli ignition a couple of years later.–
replaced.
In reply to a message from 87XJS-V12 sent Tue 9 Feb 2016:
Without knowing details of symptoms it seems more often
than not the place to start looking is the coax signal
wire connecting ignition to fuel ecu.–
stephen davis 1976 XJ-S, 1989 XJR-S, Sl SWB XJ12 x 3
gorae, Australia
