Car is a 1995 XJS 2+2:
Here is what I have done so far to troubleshoot:
(1) Checked the #5 cruise control fuse…it is okay.
(2) Also checked the rubber bellows unit on the drivers side
of the engine…it doesn’t appear to be torn and holds vacuum.
(3) Read in the archives that sometimes the ‘‘brake light
switch’’ on the brake pedal can be a source of trouble.
Archives suggested tapping the brake pedal and then seeing
if cruise control would engage. Tried this and it made no
difference. Brake lights are okay.
What is the next step in troubleshooting this issue?
I’ve ordered the service manual on CD, but it won’t get here
for a week or so…so could someone send me any official
Jaguar literature on diagnosing cruise control issues?
I also read that there is a ‘‘cruise module’’ under the
passenger foot well. I pulled that panel down but don’t see
any cruise module (pictured as an aluminum box on E-Bay).
Is it down there?..and if so, where in relation to the fuse
bank?
Lockheed,
I came across an old post of yours that I think deals with
the OEM Jaguar system. Here is what you said:
‘‘You will see there are actually two ‘‘Brake Light’’ switches,
the ‘‘Brake Switch’’ (NC) operates in series with a ‘‘gear
selector switch’’ (NO) which closes when the gear selector is
put in the ‘‘D’’ range. The other switch is the ‘‘Stop Light
Switch’’ (NO). All three of these switches must operate
correctly or your cruise control will not work. If your
brake lights are working correctly, then the ‘‘Stop Light
Switch’’ is OK. You can check the other two switches by
disconnecting the Cruise module plug, turning the ignition
to ON/Run (don’t start the engine!), and put the gear
selector in ‘‘D’’. You should have 12V at the yellow/red wire
of the cruise module plug.’’
‘‘If the above switches check OK, then you might have fault
with the Resume switch or the Master switch, or some of the
components under the hood. Checking the Resume switch is
easy - when you press it, the Blue wire at the cruise module
plug should read about 330 ohms to ground with the Master
switch off. Checking the master switch is a bit more
involved…’’
What do you mean by NO and NC? I’ll try these tests but
first must find the module…
Also, how did you gather this information on how to follow
this diagnostic procedure? From the CD service manuals?
How can I test the master switch?
How can I test to see if the cruise module itself is okay?
Also read about something called a pump that is related to
the cruise…
Thanks for the continued help!–
jstjagguy
