I’ve spent several weeks recovering from hip surgery so I could
keep my cool while entering and exiting my coupe. During this time
my fingernail have become disgustingly clean and I’ve had
opportunity to contemplate the next project. Coolong it is. I’ve
never had a cooling issue in the 18 months I’ve owned the car, so
it was never a priority. I loosened the condenser mounts from the
bottom and gained enough access to removed gobs of debris between
it and the radiator. I have decided a radiator replacement with
electric fans was due. While I’m in the area a newer GM alternator
in the air pump position, long since removed. Finally the lutz mod
and coolant filters. If I get ambitious, maybe individual bank
coolant temp gauges?
I have decided to stay with the original radiator configuration for
a couple reasons. First, after reading Bernie E’s post on the
subject it seems well thought out and reasonable. It saves
fabricating plumbing to accomodate a single pass system. Second, my
parts car came with a complete hose replacement kit.Saves $.My
question to the forum is advice on sources for an original
configuration aluminum radiator& thermostats and their experiences
with quality .Good to get back to the grime.–
89 XJS coupe ABS TH700 Raleigh NC
