In reply to a message from Veekay sent Mon 2 Feb 2015:
If you disconnect vacuum from the FPR, there should be
slight fuel pressure increase (2-3 psi) to the fuel rail,
which will increase fueling thru the injectors. However, if
you did not plug the port where the FPR vacuum hose was
connected (from the intake manifold), then you are now
allowing excess air (a vacuum leak) into the intake and very
very shortly therefter (5 seconds or so), the idle speed
will increase and stay that way.
FYI, and this was very recently posted by me, with your
newly fitted titania O2 sensors, your voltage readings
should fluctuate between 0.2 and 4.5 volts. Your readings
are constantly low. LOW voltage = LEAN. LOW = LEAN.
With a low voltage reading being transmitted from your O2
sensors to the ECU, the ECU ‘‘thinks’’ your engine is running
lean, and will increase injector open time to add more fuel
to the engine. I think the upper limit is around 10%
enrichment.
Over this past weekend, I went back and searched all your
postings for the past 3 months, and it seems this all
started when you had a spark plug ‘‘blow up’’ which cracked
the intake. Sine then, you have replaced multiple parts, but
the problem is still there. A 32 second consistent miss, and
now constant low O2 sensor voltage.
It may be time to haul your vehicle to a shop, and pay for
some diagnostic testing. You can ask for diagnosis work
only, and then you can do the repairs yourself.
SD Faircloth–
Does anyone know what the expected result should be when
disconnecting the vacuum line to the fuel pressure regulator?
At idle, with a hot engine, the oxygen sensors did not change at
all. (Mind you, I am running rich, sensors only fluctuate between
0.15 and 1.25 while driving, at idle they wander around the 0.25
range.)
Should the oxygen sensors report a change? Maybe when I’m
driving? I haven’t driven with the vacuum line plugged.
No error codes, and no squirting gas from the original regulator.
Just trying to figure out why my O2 sensors don’t wander to the
upper limits of the sensor range (4.50)
www.jaguarfuelinjectorservice.com
Jacksonville, Florida, United States
