Let start by saying thank you for your constant help. I’m learning
and obtaining the books/CD/etc. but I never seem to have the
correct diagram/picture.
I am replacing the headliner in my 19990 XJS Coupe. The front dome
light has a number of parts: The light fixture, a black metal
bezel, fabric trim bezel, reflector, etc.
Does anyone have a diagram of how this stuff fits together/is
installed?
In a message dated 2/4/2006 9:34:11 AM Eastern Standard Time, “Big Wally” torquecat@aol.com writes:
I am replacing the headliner in my 19990 XJS Coupe. �The front dome
light has a number of parts: �The light fixture, a black metal
installed?
Hi Walt:
On the 85 & 89 coupes, to remove the dome light from the headliner board, simply pry the entire assembly out by placing a flat blade, such as a putty knife, behind the bezel, and disconnect the wiring connectors. I have not disassembled it further, and the Parts Catalogue doesn’t show further disassembly.
BTW, what did you find on your ignition problem (your prior post – “Low Power”)?
85 & 89 XJ-S Coupes; 89 XJ40 VDP
Dragged out this old post to add light removal details.
In my '89 RHD Coupe, i inserted a spudger under the LEFT end of the chrome bezel. The Right end has the electrical connections protruding so will not clear the headlining until bezel is slid to the left.
