Beige
3400lbs
2 sets of 17” XK wheels. I run 245/45 Hoosiers on front. 255/45 rear.
Stripped out interior
Roll Bar
Sparco Racing Seats with 5 point harnesses
Moto-Lita wood steering wheel
Original dash, but modified to accept gauges where radio was. Aluminum ski slope on center console.
Water Temp
Fuel Pressure
Oil Pressure
Oil Temperature
Tach with shift light mounted on steering column
Perplex side windows, manual strap pulls
1994 6.0L engine, rebuilt in 2007 Roughly 7L.
New Pistons
Remote oil filter location
Stainless Steel Headers(AJ6 Engineering) with Borla muffler and side exiting exhaust before rear
wheels
Modified ECU-(AJ6 Engineering)
Be Cool Aluminum Radiator with 2 electric fans
Enlarged throttle bodies with Cold air induction routed from secondary headlamps
13” AP front racing calipers
GAZ front shocks
New Power Steering rack with Delrin bushings
Enlarged front anti sway bar with poly busings
Larger, new, power steering cooler located in front of radiator
13” Front Rotors, custom made, slotted, vented hats. Newly installed last season.
Tremec TKO 5 Speed Transmission.
4.11 Final Drive
Balanced Drive Shaft
Cooler for Rear DIFF, plumbed with switch on dash.
Custom brace for rear diff to stiffening
Replaced rear end with facelifted XJ-S so brakes are outboard. This makes changing pads
easier and keep heat away from DIFF
Rear swing arms have poly bushings
Spare rear swing arms
22 Gallon Fuel Cell located on floor of boot. Quick release aircraft style aluminum fuel cap
Adjustable rear shocks
Hello Charles,
I have a 1989 XJS. I’m looking for both side rear chrome bumpers with the rubber trim.
If they are in very good condition, I would be interested in replacing mine.
Thanks Joe
