My 95 xjs 6 cyl has a ‘‘break’’ about 6 inches before the end of the
front converter.The break is straight all around (actually oblong)
in front and flaired on the other end of the break. I’m wondering,
is there a gasket that fits in here or did the last owner have the
local muffler shop do a quick repair? My local muffler shop says
it’s too thin to weld. Any suggestions are truly welcome. Thanks,
jack–
ratsass
In reply to a message from ratsass sent Fri 22 Sep 2006:
This is not out of the ordinary on the exhaust on an AJ16 engine.
The two down pipes join (under the heat shield) to a single pipe
via an oblong union. The weld has broken.
Locate a decent muffler shop who has stainless rods, cut the shield
and bend it back. The down pipe, union, and exit pipe are thick
enough to re-weld. Once done, bend the shield back and have them
tack it to the assembly. Not concours, but will work fine.
If the break is in a spot that they have no access to it, like
upper radius, toward the transmission and the floor board, you may
elect to have the pipe removed and re-welded.
I paid a shop $35.00 to repair mine insitu.–
jack
In reply to a message from uncle sent Fri 22 Sep 2006:
Last year mine cracked at the joint just under the heat shield. I
got opinions from three shops that it couldn’t be welded. The
correct down pipe was 1300-1400 at the dealer depending on which of
the two you need. I went back to the shop I trusted, Cole Muffler,
and they ordered an aftermarket one from one of their suppliers in
that looks different, as no heat shield around the cats, but it was
around 7-800 installed.
Lee Murray '95 4.0 Convertible–
Kirbert
4
Somebody’s talking to the wrong welder. As long as it’s made of
metal, I think it can be welded. Most welders enjoy a challenge. I
once watched a guy weld a piece of titanium to a piece of tungsten.
I also watched two aluminum beer cans get welded together.
It might be something that could use more than a simple repair,
though, if several people are having the same problem. Maybe
somebody needs to figure out how to reinforce this area so it won’t
break open any more.
The
A wise decision. If the OEM part broke, don’t just buy another OEM
part. Buy somebody else’s, anybody else’s, couldn’t be any worse
than the OEM.
In reply to a message from Kirbert sent Sun 24 Sep 2006:
The guy who welded mine was just a regular Joe, it was easy to do,
as I watched. The metal was stout.
I don’t think it is a matter of support or reinforcement, I think
it was a funtion of a poor initial weld. Perhaps it was an
automated process set wrong.
I have seen those aftermarket cats, which are probably fine, for
about $375.00.–
