In reply to a message from Robert Laughton sent Wed 1 Jul 2015:
I did this job on my car, and removed the subframe to do
it. It is not terribly difficult to drop the subframe: you
need engine support beams, and then you must disconnect the
steering from the rack, and disconnect the ground strap to
the engine, and the power steering lines to the pump. I
think those are the only items, but I’d review a Haynes or
the ROM to be sure. Of course, you need to remove the
bolts at the mounts, too. Then, it is simply a matter of
lowering the subframe on the jack you have under it to
support it when removing those bolts.
I would wager you will want to replace those mounts once
you’ve had a look at them.
I am evidently one of the few who did not have much trouble
removing those lower swing arm shafts. But I used liberal
amounts of PB Blaster on the bushing points for about two
weeks prior to removing. In my case, the bushings had all
but disintegrated on one of the arms. I replaced
everything in the front suspension with poly. If I were to
do it again, I would replace everything EXCEPT the lower
swing arm bushes with OEM rubber (my car is a convertible,
and the extra compliance is worth it). The lower bushes,
because they are such a bear to replace, I would do in poly
or delrin. In any case, a material that would offer much
greater durability. You don’t want to have to do this
twice.
You can do all the other mounts and bushes without removing
the subframe; but those lower swing arms require dropping
the subframe (there are those who only lower it enough to
get the swing arm shafts out, but, why? It is not that
much more difficult to take the whole subframe, and then
you can see what you are doing).
You will need a spring compressor, too. And be careful, as
those front springs can be lethal if not removed properly.
-M–
Mike, '90 5.3 XJS Conv., 5-spd+3.54, SE-ECU+TT F/R bars
Lakewood, OH, United States
