I’ve been trying to get the stub axle out of 2 vertical links, and failed badly
the links are out of the car, as I got them second hand, but I used the same idea of loosening the big nut at the back, then tighten the bearing nut
loosening the nut went ok, using the impact wrench
but I used the impact on the bearing nut too, and strip the thread
I hoped it was just the nut, but the stub axle side is stripped too
no hammer hit managed to brake it loose, even after bashing the nut
on the other side, I only used a manual wrench to torque the bearing nut, but nut success either
I tried the press, but need to find a good way to apply the pressure, in order not yto damage the links (the stub axles have some marks, so wouldn’t be reusable imho
same for the bearing extractor I tried : no way of getting a good grip on the link
the hammer I used was about 1kg (2 pounds) , may it’s not enough to break the joint ?
I reckon my next (last ?) step is to find some way of holding safely the link so I can use a bigger hammer or the press
any suggestion welcome
