I thought the fuel pump was in the trunk- The mechanic at
the Jag service station is saying its mounted inside the
tank and would be a 4 hour job to replace it. Can that be
right?–
dsrisdall
Pleasant Hill, California, United States
If your subject line is correct then you are on the wrong list.
This is the XJ-S list (the two door coupes and convertibles), and you want
the XJ list.
I own three Series III XJs and you are correct that the fuel pump is
not located in the fuel tanks. Check it out yourself. Remove the cover
over the spare tire and you will find the fuel pump on the right side of the
car looking forward just aft of the spare tire.
Since the mechanic you spoke to clearly doesn't know these cars you
should probably take it to someone who does.
When you post your email to the XJ list, please give more
information about your fuel delivery problem. It could be the fuel pump,
but there are other sources of fuel delivery problems including clogged fuel
filter, relays, wiring, etc.
Paul M. Novak
1990 Series III V12 Vanden Plas
1990 XJ-S Classic Collection convertible
1987 XJ6 Vanden Plas
1985 XJ6 Vanden Plas (parts)
1984 XJ6 Vanden Plas
1969 E-Type FHC
1957 MK VIII Saloon
Ramona, CA
P.M.Novak7@gmail.com-----Original Message-----
From: owner-xj-s@jag-lovers.org [mailto:owner-xj-s@jag-lovers.org] On Behalf
Of dsrisdall
Sent: Monday, February 06, 2012 12:07 PM
To: xj-s@jag-lovers.org
Subject: [xj-s] Fuel delivery problem -'86 SIII XJ6
right?
dsrisdall
