— gbalthropxjs@aol.com wrote:
I was concerned when I read his post whether he had
used “Fuel
Injection Hose” which is usually stamped as such or
has the SAE code
“30R9” stamped on it.
Anyone know or look up the pressure rating of 30R9
Fuel Injection hose?
You can learn so much on this forum. There is a 30R00
which I think is no longer made and 30R07, 30R09,
30R10, 30R11. With 30R09 being best for our FI hoses.
A little from Gates and Goodyear with links for
further reading:
http://www.gates.com/common/downloads/files/Gates/brochure/TechTipsForm.pdf
Standard fuel and oil (SAE 30R7) hose is rated for
low-pressure applications at 50 psi working pressure
up to 3/8" size, and 35 psi for sizes over 3/8". This
general-purpose hose contains a light reinforcement,
and the rubber materials can be any compound that is
suitable for fuel, oil and vapors.
However, Gates Corporation engineers warn installers
that fuel formulations at many US refineries are
constantly changing as proprietary blends are
introduced according to government mandates and
seasonal influences. At times, more aggressive fuels
can extract the oils that give SAE 30R7 hose its
flexibility. The result is a brittle, stiff tube that
will greatly reduce the performance and service life
of the hose.
Fuel injection (SAE 30R9) hose or MPI (multi-port
injection) hose is reinforced to handle higher
pressures up to 180 psi. It can be used on all
injection systems that use hose clamps. It is not
designed to replace coupled assemblies on fuel
injection systems.
Fuel injection hose is designed for low permeation
contact with a wide variety of alcohols, alcohol fuel
blends, and diesel fuel. It allows 15g/m2/day
permeation whereas standard SAE 30R7 hose allows
550g/m2/day. (Gates fuel injection hose routinely
performs at 1 to 2g/m2/day
Finally, for submersible applications such as on the
in-tank fuel pump, only SAE30R10 hose should be used,
because when the hose fails, the pump will fail. Hose
construction consists of low swell fluoroelastomer
compounds in the tube and cover that resist gasoline
and diesel fuel permeation and aging. Standard hoses
have these fuel-resistant characteristics in the tube
portion only.
http://news.thomasnet.com/fullstory/512660
Goodyear SAE 30R9 and 30R11 are compatible with a
variety of fuels, including gasoline, diesel and
ethanol. In addition, the SAE 30R9 can be used for
sour gas and environmentally-friendly biodiesel fuel
applications.
The hoses also meet new U.S. EPA and California Air
Resources Board (CARB) emission requirements that
began going into effect January 2007.
