I’m resurrecting this old thread because it concerns information given on P139 of “The Book” and there is some concern about Bosch PN: 0 227 100 139 (BIM137 as well)
Currently I’m helping a guy who seems to have a problematic Marelli ignition, and per The Book, has acquired two BIM139 modules (which have if anything seemed to make his problem worse) although I’m not sure that’s BIM139’s fault. (I still have concerns about BIM 139 though, and that prompted me to search the forums and find the origin thread for the info on P139).
Per several sources the BIM139 module expects a Hall effect input (which would be a square wave), but also controls Dwell (suggesting it triggers at the start of that square wave? & then adds +xMs for dwell). Not sure if it’s expecting a positive or negative square wave. (I think negative, which would be compatible).
Sources:
https://www.mye28.com/viewtopic.php?t=106443
https://www.msextra.com/forums/viewtopic.php?f=4&t=25361
https://www.msextra.com/forums/viewtopic.php?f=71&t=54722
https://www.msextra.com/forums/viewtopic.php?f=4&t=18144
http://www.vems.hu/wiki/index.php?page=MembersPage%2FGrmRacer%2FGrmIgnition
https://forums.turbobricks.com/archive/index.php/t-25737.html
This suggest that the BIM139 will alter timing by a few mS under some conditions. (More important at high RPM).
Per dinoplex.org and discussions with the guru running that site, the Microplex MED### ECU controls coil dwell rather than the Amp/Ignition Module/Igniter.
I know for a fact that BIM124’s can work with a re-pin of one wire in the OEM connector harness, as they, like the original modules are not smart and do not control dwell. I helped one guy adapt them to his system and they worked fine.
(See my post #15 here for instructions): https://www.jaguarforums.com/forum/xjs-x27-32/marelli-ignition-amplifier-test-201800/ if further interested.
I’m given to understand that there is an about +5V signal is generated BY the Amp on the +Trigger pin, and the MED123 pulls that signal to ground (presumably to start dwell), and then returns to high to trigger the spark. (Square Wave). (Assuming it works the same way as the near identical looking MED120 … looking at the internal schematics & comparing).
The Jag uses Marelli BKL ignition module variants, as do a number of Ferrari’s using the Microplex. (They also use the same/similar coils).
Ferraris use
From Ferrari Chat these are suggested substitutes:
- Ignition Module Marelli BKL 3B
- BKL 3BD
- 064833031010
- 064833036010
- 064833131010
- 581701010000
- 581701020000
- 64833031
- 64833031010
- 64833036
- 64833131
- 940038535
- 940038535010
- AEI400B
- V86BB12A199AA
Alternatives
- Facet 9.4030
- BERU ZM061 (0 040 401 061)
- Hella 5DA 006 623-431
- Hüco 13 8083
- Lucas DAB801
- Meat-Doria 10043
- Motorcraft EDY13
- Valeo 245537
- 2595026
- 2595029
- Valeo (I) CD883
OEM / Wholesale
- Bresch BKL3B
- Ducati 28740331A
- Ford 1 637 546
- HB Autoelektrik 19010053
- Intermotor 15030
- Transpo XM631
- Unipoint IM702
Applications: ALFA ROMEO 1642. 0i Turbo 1989- ON FERRARI GT0- 328 1989- ON Testa Rossa 1989- FIAT Argenta120 1990- ON Croma2 1986- ON Cromao2. 0 Turbo 1986- ON Tempra1. 8 1990- ON Tipo1. 8 IE16v 1990- ON Uno1. 3 Turbo 1989- ON LANCIA Delta1. 8, 2. 0 1990- ON DeltaH. F. 1. 6 1990- ON DeltaH. F. Turbo 1. 6 1990- ON Prisma1. 6 1988- ON Prisma4x4 1988- ON Thema2. 0 Turbo 16V 1988- ON Thema2. 9 (8. 32 Eng. F. L)3. 0 1988- ON
Jaguar’s variant numbers:
DAC4607, DAC11677, DAC11520, DBC11677,
Various Images with markings: Magneti Marelli: BKL 3BC.
We know from the Jaguar Electrical Guides that the BKL 3BC pinout is:
1: Coil negative
2: Module Ground
3: Signal Ground (20Mv AC increasing w/ RPM)
4: +12V Batt Power
5: NC
6: Trigger +3V (0.2V to +3V increasing w/ rpm)
7: NC
From various reading I’m given to believe that the B, BC, BE designations are simply part updates for such things as better heat tolerance etc.
And these are the supposed cross matches (from modest to crazy prices):
- ALFA ROMEO: 1637546,
- Bremi: 14301,
- Beru ZM061
- Cargo: 150165,
- Cambiare 1637546 /VE520225
- C.I. XEI66
- Delphi: CE20052, CE20052-12B1,
- EPS: 1.695.030,
- Euro Car Parts: 415590030
- Facet: 9.4030,
- FORD: V86BB12A199AA, 1637546, 86BB12A199AA,
- HELLA: 5DA006623-431,
- Huco: 138083,
- Intermotor: 15030,
- Kerr Nelson: IIM024,
- KW: 465030,
- Lucas: DAB801,
- Magneti Marelli: 64833031,
- Magneti Marelli: BKL3B,
- Marelli BKL 3BC
- Marelli BKL3BA
- Marelli: 64833031, BKL3B,
- Mobiletron: IG-FT004,
- MOTAQUIP: LVIM198,
- Quinton Hazell: XEI66, DAC10923QH
- Transpo: XM631, 1.965.030 245537 2595026 415590030 465030 5DA00662, 138083,
- STANDARD MOTOR PRODUCTS LX1016
- Unipoint: IM702,
- UNIPART: GIM5083
- Valeo: 245537, VE520225, 2595026, CD883, XEI66
You’ll note a few of those align w/ the Ferrari modules.
The BKL 3B pinout is given here: http://www.dinoplex.org/PDF/Marelli%20Microplex%20MED120B%20Connector.pdf
Note critical pins match (not all, but the critical ones) on the DAB801 module (one of the pinouts I could find):
http://en.gasgoo.com/auto-images/ignition-system-407/1311539.html
I suspect/hope I could find more illustrated pinouts searching the various possible cross PNs given. Sometimes it’s hard to find that data though.
The basic concern is that a module that controls dwell could move timing by a number of crank degrees (depending on charging/discharge time) at high RPM:
Coil charging times vary, but example COP coils range from 4ms (LS1 coils) to sub 2mS (LS2 coils). Older coils … I’ve seen 4, 5, 8mS as given times… so not I’m not entirely sure what the Marelli coil needs for FULL charge saturation… -depending on voltage always.)
[strike]
At 6500 RPM, the crank is moving 6.5 degrees per mS. So a spark event change of 2mS could change timing by 13deg at high RPM.
[/strike]
EDIT: I botched my radians/second math above. The effect is even more pronounced:
So 1RPM = 6 deg/second
Sanity check: (6x60)=360
And (1/60) / (1/360) = 6
6500 RPM = 6x6500 or 39,000 degrees/second
= 39deg/ms
Sanity:
1ms = (6deg/sec) / 1000 or 0.006 deg/ms
6500 x 0.006 = 39 degrees
(Double checked w/ online calculators)
So a 1 ms variance in discharge time sees a 39 degree movement of the crank at 6500rpm.
~Paul Kobres
