I’ve just finished intalling the intake kits ‘The Growler� high
performance air intake kit from FasterJags’. I worked with Brian
refining the fabrication and installation and am extremely pleased
with the results. Not only the installation ‘handsome’, it
certainly gives you more power! After the installation was
complete, I put the T400 in my 91XJS in low gear and eased the RPM
up to 2000. Then I nailed it. The car literly jumped forward.
The different in excelleration was fantastic, plus the fantastic
sound that came from under the hood. At 5000, I pushed it into
2nd. A neck-snapping shift to way over the speed limit before I
knew. My Jag ran very good before the installation of the Growler
kit. Now it’s simply fantastic!–
Mike B
Wichita, Kansas, United States
In reply to a message from Mike B sent Sat 14 Feb 2004:
Mike, thanks for passing on your expericance. I was wondering what
changes were made to this product based on your statement ‘‘I worked
with Brian refining the fabrication and installation and am
extremely pleased with the results’’.–
In reply to a message from Jaguar-Lover-89 sent Sat 14 Feb 2004:
The changes were nothing major, Gary. Basically, it was the
location of the fittings for attaching the two hoses to the left
hand intake tube to make the installation easier and prevent
interference with the fender well. One of the hoses goes to the
PVC an the larger one back to the AAV. The AAV hose was the most
problematic because it is a ‘special’ hose and the distance and
clocking on the intake has to be right for that hose to connect
properly and reach the AAV.
Also, I rewrote the installation instructions for him. His
original instructions were fine for someone who was a Jag
mechanic. I’m not - by any means. I had trouble figuring out how
to the whole air cleaner box off the left side!
Other than that, there were no problems.–
changes were made to this product based on your statement ''I worked
Mike B
I met with Brian on Wednesday and picked up his Growler kit.
Installation was easy and straight forward. However I have a
question for the group. If I hold shifter in low and floor it of
course the GM400 shifts to second. It use to shift at 6000 rpm’s
now holding in low it shifts at 6700 rpm’s. I know the GM400 shifts
as a function of throttle opening and vacuum and the governor. With
the engine sucking more air does it make sense that the shift point
at WOT is higher? The GM400 still shifts as normal under normal
driving conditions. I haven’t had a chance to get to dyno yet since
the place is closed until after Thanksgiving but will try to do
that sometime in December. One thing I have noticed is now the XJ-S
will out accelerate my XJ12 sedan now.
Brian Welker.
2018 BEWARE:
Brian Welker is a criminal con / scam artist.
Has nice website and talks well on phone.
Takes money then delivers nothing and does not return emails or phone calls.
He’s been playing his game of fraud for years and is still at it in 2018.
Search the web and you’ll see just some of the warnings from people who have been ripped off / cheated out of $thousands by this criminal. http://www.v12performance.com/
I ordered his cool cat fan assembly for about $500. I waited for months for delivery. He continually stated the shipment was on the way. I finally got with his credit card processing company and filed a complaint. I then filed a complaint with the north Texas chamber of commerce. I finally got the gear and closed the complaints.
I ordered a radiator several years ago from Brian. I too had the same experience waited 6 months for the radiator to be delivered. I tracked down where he lived and told him if he didn’t deliver, the Local cops would be on his door step.
If you keep at Brian, he will eventually deliver. The thing is the products at V12 performance are purchases from other Vendors.
the Growler is from AJ Engineering
the hose kit is nothing more than Uro branded after market parts found on Rockauto same with the ignition
sway bars are from summit racing
EBC pads just about enywhere that sells EBC pads. amazon.com
performance break parts available at rock auto & amazon
FYI, There isn’t any company that makes a 1 piece rear vented brake rotor for the IRS. a two piece rotor package available at XKS.com or purchase the wilwool rotor and machine the center hub. The info is available at wilwood summit racing, the center mount will require fabrication
the “cool cat” is made by a company on the east coast I can’t think of the company but can get it if someone wants to know PM me.
Mark, thanks for the offer. After waiting a couple of months and nothing showing up (and several e-mails sent) I wound up buying a pair of filters from an outfit in Australia, I think!!
Tefba filters are mentioned in Kirby’s Book, and are placed in both top radiator hoses.They have a screw-on cap, and fine cleanable screens inside.As I was replacing my radiator at the time, I wanted to try to prevent crud from finding its way in. The amount of garbage the filters trapped was amazing. Nice and clean now, though!
Thanks, Dave.
Also look at RipOffReport website where you’ll find several complaints registered from multiple people who he has cheated. https://www.ripoffreport.com
ref.
Click Here to read other Ripoff Reports on V12 Performance
v12 Performance BrianWelker V12 PerformanceDoes not Perform DallasTexas
· V12 Performance BrianWelker Will not return $200 core charge, doesn’t answer phone or email DallasTexas
· Brian Welker / V12Performance / FasterJags Brian Welker 2018: Briantook order and and money ($491.09) for QuickCat air intake kit. No kit was received, and since taking order he has not responded to telephone calls or email messages. Dallas Texas
· V12 Performance Jaguar BobFromTexas CatCooler, Jaguar Radiator, BrianWelker BRIAN WELKER is a THIEF, V12PERFORMANCE IS A SCAM, DO NOT FALL VICTIM LIKE THE REST OF US…. HIS CRIMINAL ACTIVITY WILL BESTOPPED Dallas Texas
· Brian Welker v12Performance I sent him Paypal for $467USD for air intakes. Never delivered. This was on Feb 16 2013. I have not done a report to Paypal as I still believe a different approach may deliever the goods. DallasTexas
· v12 performance BrianWelker Ripped me off, lied to me, wont answer emails or the phone, Broken promise Dallas, TexasInternet
· V12 Performance BrianWelke rFaster Jags $200 stolen Dallas Texas
· V12 Perfromance BrianWELKER Took $700 never sent items, no return emails, no returned phone calls, waiting three months. Dallas, Texas
· V12 PerformanceFasterJags.com Incomplete order - does not respond to multiple emails and phone calls - RIPOFF Dallas, Texas
· v12 performance Products not shipped, no response Dallas Texas
· Brian Walker. V12performance. Faster jags. Parts not sent. No replies. Monet taken. Dallas, Texas
Complaint ID#: 91445839
Business Name: one stop source for Jaguar XJS / Brian Welker
The Better Business Bureau has made several attempts to contact Brian Welker regarding the above referenced complaint. We regret to inform you that the company / Brian Welker has not responded within the normal 22 day timeframe and accordingly we are closing the complaint as Unanswered.
The Better Business Bureau develops and maintains Reliability Report ratings on companies in our service area. This information is available to the public and is frequently used by potential customers. In the case of your complaint, the company’s (Brian Welker’s) failure to promptly give attention to the matter will be reflected in the report we give to consumers about them.
Sincerely,
Dispute Resolution Department
BBB Serving North Central Texas
